Which Head Studs with a 6-Bolt Block and 2g Head?
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I have a 98 Gsx with a 6 bolt block and a 2g head. What size head studs should I get? One extremepsi's website they have a bunch of different mm sizes for the arp studs.
I just search and it said that I will need to drill out the 2g head to make these fit, is that true?
Right. The 6 bolt uses 12mm studs and the 7 uses 11mm studs. I've done the reverse, tapping out the stud holes in the 2G block for a 6 bolt head, when I test fitted some 11mm stock bolts in the early head's holes there was a crap-ton of slop, seemed like more than 1mm difference should've been.
That all depends on the bore size of your block, if you haven't had any machine work done or even if you went .020" over the 85.5mm will be the route to go. The 86mm is for people that have had to go .040" over and the 87mm is for .020" over 2.4l :)
Be sure to check this out when you're ready to make a purchase, we will not be beat in regards to price!
DSM Cometic and ARP Kit - Modern Automotive Performance
  • Wanted 2g 2g Hood latch support
    On the hunt for the support that holds the hood latch assembly.
    • jesse12345
  • For sale 4G63 Hallman ES Boost Controller
    Boost controller
    • jpturbotalon
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
