Which dimmer switch wire do I use?
mystiquesvt
Jan 14, 2005
colorado springs, Colorado
Which dimmer switch wire do I use from the harness to light up my boost gauge?
I believe I ran it off the green/white. But don't take my word. Do you have one of those connection testers that lights up when the circuit is connected? That's what I used.
Its the black w/ yellow stripe and the green w/ white stripe, (cant remember which goes where) but if you wire it backwards when you turn the dimmer up the boost gauge light will go down so just flip the wires if that happens, 50/50 chance
I figured it out.
it,s the black wire with the yellow stripe and red spacer.
THANKS for all your help.:thumb:
