which cams should i use??
Solace Lost
78
Jul 28, 2011
Lagrange, Georgia
I just received a used head in the mail. It is slightly different than mine and equipped with different stock cams. The ones in my original head have a stamped "G" by the can gears.. the new ones have "HF" stamped by the gears.. anyone know which ones are better??
Assuming your new used head is stock I would stick with with what is already installed in the head... Mainly since cam bering clearance is broken in already... stock grinds are not drastically different so I would stay with what is already installed. Stock grind is not that important until you are running high boost rates. If you have a big turbo and supporting mods then you can upgrade to a bigger after market cam. You will generally not see much if any cam difference under 20 PSI boost levels and stock rev limit... Sorry!
