where to start on dsmlink?
FirstDSMTimer
75
Jun 26, 2011
Baltimore, Maryland
Ok first of all I found all my boost/vac leaks fixed them. Then i replaced my iac and tps and tb set the throttle stopper and tps now I am having a hard time getting it to run right when i got dsmlink i said i had a 2g maf with stock injectors. Now i still have the 2g maf but i have seimens a delka 750cc injectors and a wally 255 rewired but i cant seem to get the fuel pressure below 50psi with vac line removed and my vac reading is low like 8. I set the deadtime and global as said on another post but then it idle surges all over the place. should i set up more air flow? my mod list is up to date so anyone that can help please do because now im lost.
here is a log but i was messing around with the biss and the airflow ratio.
