Where to put external wastegate?!?!?
jt1583
86
Mar 24, 2004
alpharetta, Georgia
I was planning on putting it on the number 1 runner but two exhaust shops said thats a big nono because no one welds on cast iron because it will crack. Where else can i put it??
You can weld onto the exhaust manifold, but its tricky. You need to constantly heat up the cast iron manifold so it won't crack and use nickel rods for welding. Find someone who is a really good welder and they can put the wastegate on your manifodl so you dont have to buy a new one.
my o2 housing has two pipes, one coming from the internal wastegate and one coming from the exhaust wheel. should i get them to chop off the tube coming the internal gate, weld the flange there and seal the other end of the tube that connects to the o2 housing? ill have pics up in a few minutes
