where to get parts for external wastegate
brandons 95
95
Jan 13, 2006
deltona, Florida
Where can i get the parts that I need to do external wastgate on my e16g, but I dont want to change the exhaust manifold because I just bought the new dnp race one :talon:
if you just bought a new race manifold without the flange from the collector, you will have to go the o2 route. For one, you will need to get rid of your internal flapper and open up that area first in the turbine housing. then you will need to buy/make a custom o2 housing that will let you utilize an external wastegate. you can choose to have it dump or rerouted towards the exhaust, up to you.
look up victoryperformance.com..
What do I need to do to get rid of the internal, I am not able to access that website for some reason any other ones thanks
So I just leave the hole open, I have seen in some threads they say to weld it shut, do you know anyother places to get the 02 setup, thanks
The only reason to weld the flapper door shut is if you are running an external wastegate off of the manifold. When you are running off of the o2 housing, you want the flapper removed and the wastegate hole ported.
Here are some links for o2 housings set up for an external gate:
http://www.slowboyracing.com/shop.php?sid=&cat=593
http://www.extremepsi.com/store/customer/product.php?productid=17651&cat=672&page=1
