Where to get engine motor mounts?
Prothanes? Solid aluminum? JNZTuning for stock mounts? I doubt you can just get the bushings. You would need to get the old ones out and then hydraulically press the new ones in...IF they sell just the bushings.
There's two different ways of going about this. Some companies sell bushing inserts, which require you to remove the factory bushing and replace it with a new one. The problem with this is the old bushings need to be cut out and then the new ones must be pressed in. This is the biggest pain in the butt, but if you have the time and the patience, then more power to you. This is the cheapest route to go for a firm set of motor mounts.
The second option is to buy new mounts with solid bushings already pressed into them. Going this route costs a good amount, like some of the members stated, but it's well worth it if you don't have the time. You have a ton of options if you should choose this route...
Jerry
If you are looking for an extremely cheap route. Hit up Mitsubishi Graveyard for a set of used motor mounts. I sometimes get used pats so I could do work on them without having to take them off the car. For example, I will build my head in the future, I have two heads laying around. I will build one and then swap it out with minimal down time.
