where to buy an alternator for my awd tsi 96
randizzle420
262
26
Sep 20, 2009
El Centro, California
Anyone know where I can buy an affordable alternator for my 96 tsi awd? My car was acting funny losing power and such then the battery light came on and it died on me. I charged the battery up, put it back in, and when I was driving it the lights went dimmer and eventually the car cut off on me. So I suspect it's the alternator. Also are the alternators for the gsx, gs-t, and tsis all the same, or is it different for the awd?
Have it tested first just to be sure it's not some other electrical issue. I had alternator woes a couple months ago and if I had to do it all over again I would have gone to the damn junkyard and pulled one.
Reason being, I went through FOUR (meaning I'm on my fifth one now) autozone reman alternators.
So I would recommend going to a junkyard and pulling one. Change it out right in the parking lot if you can, that way if it's a dud you can take it right back in to them and try another.
Are the alternators the same from 95-99 up for all turbo talons and eclipses?
4alterstart.com
Get a better, larger powered alternator .. I currently run their 135amp alternator after I went through 3 yes 3 different autozone alternators after my OEM one died. Same price as OEM might as well get a higher capacity. And they have a Life time warranty. Spend the money do it right once. It solved any power issues I was having.
