Where should i?
Start at .028" and if it blows out the spark, lower the gap.
Yea .28 would be a good starting place but I suspect you might end up going lower.
On our Supra we have the gap down to .22 @30psi (GT35R)
That's how I would go about it
Well its actually in a BMW E36 (Bimmota as we call it)
Its the 1JZ 2.5L Supra Motor. On 30psi we were making 530whp. Stock internals
I agree with bradselph. I'd suggest gaping them at .025 with those mods. You definitely don't want to widen the gap at the risk of blowing the spark out. Good luck!
so i gapped them at .028 it runs and drives fine but now its starting to sputter/fuel cut kind of feeling and its never done it before and the check engine light comes on when it starts doing it only on full throttle tho...now gotta invest in some new spark plug wires since those haven't been change in 25k or Oct 2010 LOL
You have link installed?
It's possible its either registering knock/timing pull if that's the case. I have mine to come on at 2*+ of pull.
Sounds like spark blowout to me.
Lower the gap to .025 or even .022 and if it still does it or doesn't get any better then look else were for the problem.
I have noticed when they tune cars at the dyno they always tell em between .18-.25 gap.That is on car's just about same horsepower you should be running on that setup.
