Where should I put my GM mass air sensor? *pics*
GooeyGus
459
Sep 23, 2009
Marysville, Washington
Hey Guys,
I finally got my couplers for my GM mass air sensor, and I'm ready to install it.
My question is, where should I put it? I have a pretty good idea of where I'm going to locate it, but I would like some feedback/other ideas.
Here's what I'm planning: In the picture below you see the throttle body elbow, and then a coupler, and then the upper intercooler pipe. My plan was to cut a bit off of the TB elbow, and a bit off the upper intercooler pipe, and putting it basically where the final coupler is now. See pictures below.
Thanks!!! :hellyeah:
In blow through with a MAFT or ECMLink V3, put it anywhere after the BOV. I recommend placing it as close to the TB as possible to eliminate as many boost leak sources as you can. You also want it in a straight section of pipe so that flow is as laminar as possible through the sensor. Don't place it directly in front of the TB or in a bend of the UICP.
That would be where I would put it. Make sure that you measure how long the MAF is with the coupler and put it where the pipe is as straight as you can get it, but otherwise you should be fine.
You should put it here:
Then go here and read.
If you are set on using the GM MAF, putting it where you are thinking will work just fine for blowthrough, or you can run it as drawthrough as it was intended.
so you need us to tell you to remove your cruise control?
the non-cruise throttle cable is already in the mail :thumb:
I AM intending to run speed density in the near future, but I got a really good deal on the MAF + translator so I decided to pick it up.
I got my GM MAF and translator all set up yesterday. With all the stories I've read, I was almost positive that I was going to have to do a bunch of tweaking to get the car to run right.
BUT... I set up the translator to run in "MAF mode" (as opposed to RPM mode), set the dials to the base 450cc injector setting, and it runs GREAT!!! I cant even tell that I've switched to a different mass air sensor. It had a little bit of trouble with the idle at first, but it was only because I reset the ECU. After a day of driving it feels pretty damn good.
I didn't bother hooking up the RPM signal wire. I figure if I end up needing to do RPM-specific tuning, I'll do it in DSM link.
My only problem is that I need to do a bit of modifying on the fitment. One of the couplers isn't grabbing very well and it keeps popping off. Good thing I have it set up as blow thru... I could drive it home and it still ran great with a blown off charge pipe, I just couldn't boost! :p It holds up to 10psi with no issues, but when I get to full pressure (16psi) it blows off... so I've just been keeping the boost under 10.
I don't know if I would pay full retail price for this setup (around $300 for sensor and translator), but for the $100 I spent on the setup, I couldn't be happier. It was truly plug-and-play.
    • Sdcryan1
