2G Where is the fuel pump relay on a 2g turbo
flashburn02
169
Jul 10, 2006
Akron, Ohio
I am not hearing my fuel pump kick on so I wanted to check the fuel pump relay. I can't find and I have the entire center console pulled out. Can someone tell me where it is located? And hopefully someone has a pic of it. There is no good description in the Hayne's manual either.
On the passenger side of the console behind the plastic cover, almost below the radio. Some 2g's had a large gold box and others just had 2 black relays. You will see where 2 small bolts with 10mm heads go through the metal dash brace, spaced about 1" apart. Remove the bolts and the relay will slide out from behind the brace.
Thanks, I am gonna check right now.
I have the relay out, and it is one larger gold box with 8 pins on it. Any idea which pins I need to test for ohms of resistance in order to check if the fuel pump relay is actually bad?
Also, if the relay is good but the pump still doesn't get any power, where should I check next?
    • george bromwell
    • pma1123
    • Sdcryan1
