1G where is the fuel pump relay
hey guy the fuel pump relay is located on the right side of the centre consol directly under your deck. the procedure is to pop off the plastic covers and take out the three screws that hold the carpet side panel of the centre consol out. once done, look just behind the furthest screw forward that you just took out and you should see two small, probably golden coloured screws lined up vertically (one above the other about an inch apart) you can't miss them. take those out and remove the golden coloured box out from underneath the consol as much as you can. there probably won't be that much slack in the wires, but unclip the harness and you have your fuel pump relay. its actually called the "electronic fuel injection relay" and it serves 3 purposes. as you turn your key to ON it provides power supply to the fuel pump, (in which you should hear for 2-3 seconds before you go to start) fuel injectors, and the ECM. i know this because i'm currently having problems with my cars fuel pump not turning on when the key in ON or when i go to start it. therefore no fire just keeps cranking. but good luck if your having problems.
