WHERE does the main O2 sensor hook up to (o2 housing o2 sensor)
oVer-Boostin
140
Nov 25, 2004
Commerce, Michigan
Can anybody show me where the MAIN O2 sensor hooks up to?? Mine is unplugged and I can seem to find where it is supposed to plug into. HELP!
The harness that it connects to should be on the passenger side of the block just above the tranny. Is that what you are referring to?
is this it? i just took a picture of it.
so then what is this other connector that looks just like it?
Wow, it looks like the mechanic that rebuilt your engine really slacked off.
I wish my O2 sensor plug wasn't bolted on like yours, it's a real pain to try and get it plugged in/ off when you can't move the plug around.
I'm not too sure what that 2nd plug is.
yeah that plugs for the cruise i took mine out and have that in the open also. its right below the waterneck if you trace back from your o2 sensor the the block that other end is actually connected to the car. when you do find it unplug it from behind not sure if you understood me.but anyhow the connectors are clipped onto the block here are the pics the lower hose is the lower radiator line so you can figure it out. hope this helps.
Agreed. Deifnitely a pain to clip/unclip when attached to the car like that.
so then i guess i need a new o2 sensor because the one thats on there now looks like this.
alright, im gonna go to autozone and buy one now, does it matter wich one I buy as long as it is the right one?
