Where do these vacume line hook up to?????
96GSXMN
42
Jul 28, 2008
circle pines, Minnesota
These are all to my 1996 GSX and I am getting frustrated on there they go...
Ok the first one is long and goes into the fire wall on the passenger side.
<a href="http://s133.photobucket.com/albums/q70/munson4406cuda/?action=view&current=Picture195.jpg" target="_blank"><img src="http://i133.photobucket.com/albums/q70/munson4406cuda/Picture195.jpg" border="0" alt="Photobucket"></a>
ok this one is on the valve cover and I dont know whick hose hooks up to it.
<a href="http://s133.photobucket.com/albums/q70/munson4406cuda/?action=view&current=Picture196.jpg" target="_blank"><img src="http://i133.photobucket.com/albums/q70/munson4406cuda/Picture196.jpg" border="0" alt="Photobucket"></a>
this one goes to the air box air intake hose
<a href="http://s133.photobucket.com/albums/q70/munson4406cuda/?action=view&current=Picture197.jpg" target="_blank"><img src="http://i133.photobucket.com/albums/q70/munson4406cuda/Picture197.jpg" border="0" alt="Photobucket"></a>
Ok and the final one goes to where the turbo is.
<a href="http://s133.photobucket.com/albums/q70/munson4406cuda/?action=view&current=Picture199.jpg" target="_blank"><img src="http://i133.photobucket.com/albums/q70/munson4406cuda/Picture199.jpg" border="0" alt="Photobucket"></a>
Could anyone help I have been banging my head against a wall since I started this car.........
Thanks for any help
I'm not clear on what the first one is. The hose coming off your intake pipe should go to the valve cover. The one from your turbo, I'm guessing is coming off the wastegate actuator, should go to either a boost controller or a boost source.
The nipple on the valve cover goes to the smaller rearward facing nipple on your intake snorkel (probably the other one in question below it). The one that goes to your turbo should connect to a nipple on the compressor cover on one end and the other end should somehow connect to your BCS which is under your coolant overflow tank or it may go into a T that also connects to your BCS. If you need to find your BCS there should be a small line coming from a forward facing nipple on the underside of the intake snorkel that also goes to the BCS.
Thanks for any help
first one looks like charcol canister vacum line
1. Windshield washer nozzles.
2. Run a line from the valve cover breather nipple to your intake pipe. There will be 3 holes in your intake pipe. The smaller two are for the valve cover breather line and the BCS line. The larger is for your charcoal canister.
3. Looks like the charcoal canister line (bigger than the valve cover line). If not, see above as to what it might be.
4. This could be one or two lines. It could either run from the compressor housing to a tee or from the wastegate to a tee. Both of those lines connect to a tee which then runs to the BCS.
