where do these vacume lines go?
2gTSIFZone
108
Jun 24, 2010
Riverside, California
i labeld the 2 vacume lines that are in question... and if anyone has any suggestions on how to remove my filler bolt on my transmission i would be very happy for ideas.... KEY WORD on that filler bolt, the previous owner rounded it off and seems to of used lock tight on cross threaded the bolt in there =/ not even vice grips,channel locks nothing would get it off =/ neightbor is going to let me borrow his torch to heat it unless someone has a better suggestion :D and yes ive tried EVERYTHING that i can think of ( using a 16 rather than a 17, WD-40, Breaker Bar ect.) thanks =)
picture is not so good but looks like tb lines so here is the lay out for all your vac lines.
as for the plug welding a nug on top of it and then breaker bar to take it out could work.
