GeoTalon91
- 79
- 1
- Feb 8, 2012
Laredo,
Texas
Ok so shortly after purchasing a 92 Eagle Talon for 1200 I gave it a run through. First I noticed that the past owner was running platinum plugs on it
nono
. I switched them out for some autolight coppers, i tried getting the NGK at Auto Zone and O Reileys, but they had to be special ordered.
Then some of the BC to wastegate hoses were all messed up. Got that all fixed up. The car was running pig rich and would stumble flat on its face at about 60MPH. (Almost like a very bad stuttering).
I thought the car might have some boost creep, the stock boost gauge read 14 PSI, I installed a proform boost gauge and it read 10 PSI. At what PSI does fuel cut come at? I moved the wastegate a bit to see if it was working and it was, looked very rusted but still functioning after I used the pliers to move it back and forth.
Then we took it out for a test drive after new plugs were installed and new vacuum lines were installed. I let my dad take it for a go and it was still suttering over 60 mph. All of a sudden the oil light came on and my dad shut the car off and clutched the engine. We came to a stop and checked the engine bay for oil leaks-none- Then we checked the oil on the block - it was full. We tried cranking it and the starter would not engage the flywheel it sounded like it was slipping.
Thinking that the engine had seized we took a spark plug out, put the car in 2nd gear and pushed it while my dad looked inside the cylinder. the pistons were moving up and down so the engine was not seized. Then we pulled an old school move and tried turning the engine on with the clutch and 2nd gear. It felt like it was still in neutral, no compression.
Finally I decided to check the timing belt and low and behold it had broke!
ohdamn
It broke in half, it looked like it snapped. The belt looked like it was new though, but I'm wondering if they had installed it wrong, which is why the car was running pig rich and would stutter at 60 MPH due to timing being off?
What do you guys think?
Also at what PSI does fuel cut off take into effect?
And I know there is a very good chance that the valves bent. Should I put a new timing belt and check compression or take the head off?
What timing belt do you guys recommend?
What headgasket do you recommend?
Thanks to everyone in advance for the help
nono
. I switched them out for some autolight coppers, i tried getting the NGK at Auto Zone and O Reileys, but they had to be special ordered. Then some of the BC to wastegate hoses were all messed up. Got that all fixed up. The car was running pig rich and would stumble flat on its face at about 60MPH. (Almost like a very bad stuttering).
ohdamn
It broke in half, it looked like it snapped. The belt looked like it was new though, but I'm wondering if they had installed it wrong, which is why the car was running pig rich and would stutter at 60 MPH due to timing being off?What do you guys think?
