o0_pyro_0o
- 57
- 0
- Feb 24, 2004
Manchester,
New Hampshire
pretty much where ever I happen to feel like it, usually it's over 3k though
gsxtacy said:Aren't our 420A bretheren limited to 6250?
I know NT 4G63's will rev higher than 6250, But my old friend in his Neon said he couldn't rev past 6200.
I dunno.
Shift when lateral acceleration has ceased, another words if you are not gaining speed, shift.
I shift where ever feels best for my mood, stupid van load of step children beside me....downshift from 4th to 2nd and get-tha F away., if not might find Bubble-Yum in my passenger seat!!
whatever.
gsxtacy
BGRIPTP said:I think the rev limiter is like around 7800 for the 420a's.
Theb95tsi said:i see how all people asume that hes talking about racing all the time
driving regularly: 3000 to 4000 rpm
racing: 6500 rpm
)TurboGraphX said:I personally know a few 420As that make 10 second passes... so who says that the speed limiter isn't needed?
exactly16g-95gsx said:As mentioned shift points should Ideally change by gearing. The gearing of each specific gear should be the indication of shift point, not one sole rpm to hit in every gear. Ideally you should shift at the point where the wheel torque in the next gear at the entering RPM would be greater then the wheel torque in the current gear at the next rpm. This means that depending on the change in gearing for each gear should determine how long you should stay in each gear. For example, 1st gear is very short, therefore you should hold it longer in that gear than you would in 2nd gear, so say 6800rpms in 1st as opposed to 6500 in 2nd. Ideally as mentioned 4 seperate dyno plots would be perfect for determining the perfect shift points, but for many people this is difficult. Stock cams tend to kill any turbo at around 6500rpms, and obviously the T25 dies off even earlier than that. Larger turbos will keep the wheel torque up longer, as will cams and SMIM's, therefore shifting higher with those particular parts is better. However shift points are entirely dependant on each person's setup and gearing. Hope that helps answer your question and give you a better idea.
Coup D E'Tat said:The 1/8 mile doesn't count.
lowridin2g said:There are several 420A powered 2Gs that spank the 4G63T powed 1G and 2Gs on a regular basis.
.................... and then i got high, and then i got high and then i got hiiiggggghhh la da da da da da
(as quoted by afroman)
