What's your BEST/Worst mod???
garage16
133
Oct 4, 2008
toronto,
Well not sure if anyone will have the same post on this topic but out of ALL the mods you ever done to your motor, what would you say is the #1 mod your really happy with and a mod that you will never ever do again or ever buy again.
Could be your best part for the buck or just a mod that your not happy with
Lets hear them guys........
:thumb: Was swap my non-turbo setup into a Turbo set up
:notgood: Buying HKS valve springs
Best: Going from stock SMIC to HRC SMIC + RRE UICP. Noticeable better low/midrange torque + incredible boost response. Spool from idle with T25.
Worst: BOV dump tube cut. Produced BOV flutter with 3000GT BOV which I had that time.
Best mod: probably either the exhaust or the 50 trim
Worst mod: cutting the dump tube off the intake. I changed to an ebay metal intake like a month later. waste of JB weld.
Best: E85
Worst: The cracked JMF SMIM that Tony Davis of OKC sold me..
SMIM is now repaired and should be awesome.
Best: FP3052 turbo
Worst: My Newly installed JM Fab intake manifold (because it whistles so loud...I can here if from my car from over 100 ft away....shit is loud and embarrasing)
Best--E85 all the way. Not really a mod but the best thing I have done to it by far.
Worst--Buying a maf-t/safc when I should have just got dsmlink. 1200cc injectors still running great on just maft/safc combo.
Best: Ebay 16G, beats the hell outa a T25 that wouldn't hold more than 11PSI
Worst: Blitz BOV, piece of shit leaked worse than the stock one. But it was free and I sold it for $60 :thumb: .
Best:
E85 and DSMLink's ability to tune humongous injectors, which only cost a tiny bit more than a set of 550's.
Worst:
1) Ever attempting to fill stock motor mounts with Window Urethane. It take a week to do because you have to fill it in layers, it's a HUGE mess, and when you're all said and done you've spent almost the same as what Prothanes sell for on eBay.
2) Thinking I could build a working manual boost controller. I spent $12 on fittings, just over an hour making it, and I never installed it because it failed my bench tunability test. The window of adjustability was so narrow it never would've worked properly. I would've been better off buying an $8 MBC from eBay to get the same thing. There's a reason professionals build these things.
best 2g mass convertion
worrst is E-bay coil overs
Best - Devils Own Progressive Water/Meth Injection ( eliminated knock and allowed me to up boost by ~ 7 PSI and tune for a 11.2 A/F ration on Pump Gas and no knock ( ~ 70 HP increase on Dyno!) Best HP bang for the buck, Period!
Worst - Greddy RS BOV - wouldn't blow off correctly and aggravated Off Boost Surge regardless of spring adjustment
Best- FP race manifold and Comp 272's. Pulls f***ing crazy now. OMG
Worst- Greddy RS bov. :notgood:
