Whats wrong with my car??? VIDEO Boost leak? Coil Packs? CAS?
If you had a huge leak your car wouldn't build boost at all. Have you tried a leak test to see how much pressure you can build in the system? Try this and see if you can hear where the sudden leak is coming from. It seems you get to 12lbs. boost and you suddenly loose all pressure, immediately. Possibly you have a problem with the BOV or vaccuum hoses to the wastegate.
Plugs are new and gapped to specs. I will check for the boost leak though.
What about plug wires? Although, I didn't really hear the engine break up at all...
I vote: Boost Leak
The stock ECU bin's fuel map targets low 10's for AFRs and at really high loads the target is in the 9's. If you've got a boost leak and your still running the stock MAF, your going to be even richer than 9's. BTW, at stock boost, DSM's are kinda sluggish.
The wires are new also...about a year and a half old. I'm going to have to check the ignition first because the car still boost fine. I'm gonna get new coil packs and also new wires. Spark plugs are still fine.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
