Coil packs
Bluecifer361
85
9
May 31, 2020
Corpus christi, Texas
Well it looks like I’m getting no spark to a spark plug I have replaced the wires next is the coil packs the oem ones seem expensive so before I buy one is their a aftermarket one anyone suggest
Did you ground the spark plug cases when testing?
Note that with a waste spark system both spark plugs connected to each coil fire together.
Try swapping the spark plug that doesn't fire to the other coil to see result.
Is this a 4G63T or 420A?
4g63t
no I didn’t ground anything I just laid them on a towel do I need to ground them if so how would I go about that?
Yes you MUST ground the spark plug casings. Clamp them against some engine metal that's unpainted. Or use battery jumper cables on each to ground. Note that both spark plugs on a coil are actually part of the same electrical circuit (one on each end of the secondary coil's winding) to ground.
