whats the best 1990 shifter bushing set up?
JUNKYARD1GTALON
Apr 2, 2006
ATASCADERO, California
I've been trying to find shifter bushings for my 90 talon tsi. ive seem the symbroski kit and dont know if the bushings for the shifter piviot are included. it says that the 90 kit is different than 91+.i know that the bushings in the kit for the bracket to floor connection are good but what i really need is the piviot bushings. also i've seen the skate bearing mod for the under hood shift lever and it looks like it will work. can anyone find where to get a full bushing kit for the 90shift lever?
is this where this goes? the 90 kit dosent come with this though. where do i get these bushings and the ones that are behind the nut facing the driver side?
is there a short shifter kit that has all the bushings?
i heard some one say that theirs came with a stif shift kit from slowbnoy racing. can anyone confirm anny of this????:talon:
here is the likk to slowboy. what mod are they talking about??
http://www.slowboyracing.com/more.p...9a&PHPSESSID=a13eaf311ef88c89dcf75ed08223579a
my mods to my shifter are
symborskit stiff bushing kit
underhood rollerskate bearing mod
cut and welded stock shifter
drilled the shift arm fork and relocated a 1" in
new shifter stop points
2g shift know
and now my throw up and down is about a 1-2" of throw the side to side still has some slack but nothing to big.
and id suggest you go to the dealer and replace all the bushings in the shifter, its like $3 for one and there are 5 of them but its so worth it
COOL! I have tha square piece of plastic(shoe) and i installed it a while ago. it helped. the problem is in the piviot bushings. my mitsu dealer is a lazy fool. he's like "i need a mitsu vin#, i cant do anything with this eagle/dodge #". i tell him the shifter bushings for the 90 talon are the same as the bushings in any 90 eclipse with the f5m33 5 spped tranny. he then says " well when ever i order these parts for YOU GUYS they are always wrong." he sucks! :notgood:
so i had him print me a diagram and when he ran the part #'s i needed he gets two numbers for every part. i know that the mitsu part numbering system sucks but come on! is there a way to get an after market bushing set or am i going to have to just buy two of everything from the dealer and figure out which works?
