Whats everyone running fuel pressure wise?
Re4peR26
74
Jan 10, 2008
Ravenna, Ohio
Well in my car i have been running 42.5 psi at idle and about 70psi at 18lbs of boost. Werid thing is thats the only way my car likes to run.... so i just want to see what some of you guys are running as far as Fuel/Boost
I believe 1g fuel pressure is supposed to be 36.3 with the vacuum line disconnected. Having high fuel pressure without compensating for it with some sort of tuning device, is going to cause problems.
Im using the aero one. And as far as problems go this is the best my car has ever ran. thats being completly honest. She doesnt want to run when the fuel pressure is that low.. stumbles on her face and if i blip the throttle it wont rev it will bog when its that low, Now all she does it want to go without any hesitation.
Your fuel pressure should be:
Have you checked for boost leaks lately? Did you put teflon tape on your AFPR fittings (the NPT ones, not the AN ones)?
Yes, I had 3 boost leaks fixed them all. And yes i used teflon tape on the fittings. Casue i have the liquid filled gauge under the hood and the electric on in the car.
Looks like you are testing it with the vacuum hose still connected @ idle which would explain your ratio being greater than 1:1 with boost. Proper way to test is with the hose disconnected as stated above. Judging from your #s, it looks like your base fuel pressure is at 52psi @ idle with the vac hose disconnected.... thats too high.
It would look that way. Calculating from provided boost and from a guess at vacuum.
Assuming the gauges are accurate.
Fuel Pressure (psi) = Base Pressure (psi) + Reference Pressure (psi)
70 = x + 17
70 - 17 = x
53 = x
42.5 = x + (-19 in hg)
42.5 = x + (-9.3 psi)
42.5 + 9.3 = x
51.8 = x
Now is this bad?
It's different than the factory base pressure but as long as the car is retuned for the change in effective flow rate of the injectors it's not "bad". On a stock ECU without tuning, it would be seriously rich and imply something else is wrong if it ran well.
70 psi at the rail may be a problem. As you move back to the fuel pump there are restrictions (losses) that add to the actual pressure seen at the pump. The pump its self has a pressure relief valve that will begin to vent fuel once exceeded reducing the pump flow. These are typically around 70-80 psi except for the "HP" pumps.
Very true.... Your a real smart guy i give you props on that.. here would be a good question if i was running to rich i would have some black smoke or black plugs.. Well this is not the case for me. No smoke and plugs look good. and a correction to what i stated above.. At 16-18psi its running 63 psi
Update: i set the base psi to right around 38 closest i could get it, Then connected it took it for a drive... Well under boost or hard accelation it was decent... but light throttle no way boggs all to hell.. So went back home upped it to 40psi base then it was a little better still bogs a little bit more. So im just going to put it back to 43 base psi.. seems as if thats all it gets along with.
Is your car an automatic? I don't know enough about 1g awd options (like maybe awd/gsx didn't have an auto option on 1gs). If yours is an auto and from what was mentioned already in the thread, 43psi base fuel pressure might be correct.
What kind of FPR's are other people using? Has anybody used an MSD2222 fpr on there car? I have one that I used on my starion and I am going to make a fuel return fitting for the rail so that I can use this regulator and not have to worry about all tha AN fittings. I am eager to see if this makes as much of a difference as it did on my Starion.
And I should shoot for about 36psi on a 1g manual by the info above right!
You could do this, but the stock FPR will do just fine until you start pushing the stock fuel system. I'd recommend spending your money on parts in the order you need them. But I have no idea if that FPR would work or not. As long as it rises at 1:1, is adjustable, can flow more than the stock FPR without overrun, and can be installed, why not? Most folks around here use an Aeromotive AFPR.
Well when I plan I using this I hope to be running a walbro 255 soon, but I never really hear about anybody using the MSD2222 on thier DSM it does have all the features you mentioned. Thanks for the feedback.
my car is 5 spd.. is it really neccasry the run at the stock psi i have fuel system upgrades 16g turbo all of the supporting mods. I did another boost leak test found another one.. fixed it. didnt help any.
Sorry I wasnt trying to hijack your thread....have you checked your plugs and wire to make sure that they are gapped good and the wires suppling good spark. The raised fuel preasure may fix your hesitation but I dont think its the cause for it.
Base fuel pressure *should* be independent of the turbo and FP you have as long as you're within the capabilities of your injectors.
Think about it like this: The injector is just an on/off valve. The ECU says "open" then quickly says "close". The ECU knows that you have 450cc/min injectors and knows that you have 38psi-ish fuel pressure. Therefore, it knows that a specific amount of fuel will be delivered when it opens the injector for a specific duration (called the pulse width).
The fuel pump just has to provide *enough* fuel to keep the fuel pressure high enough. The FPR is the part of the system that is responsible for keeping the pressure "just right". As long as the fuel pump is cranking out vast quantities of fuel and as long as the AFPR is capable of letting enough of this recycle back to the gas tank, the fuel pump doesn't matter.
It's all about keeping the pressure difference on each end of the injector right at 38psi. Keep in mind that the two ends of the injector are the fuel rail and the intake ports. The intake ports, however are boosted (connect right to the intake manifold). So when you're running 10psi boost, the FPR has to keep the fuel rail pressure at 38+10=48psi pressure. Every increase of 1psi boost requires a corresponding 1psi increase in fuel rail pressure by the AFPR. That's all the 1:1 stuff folks talk about with an FPR. Also, when idling, you might have -10psi in the intake manifold. The FPR then has to keep the fuel rail pressure at 38-10psi=28psi pressure. That's why there's a vaccuum line on the AFPR from the intake manifold (lets it know the IM pressure). But wherever your IM pressure is at (vaccuum or boost), the FPR is keeping the *difference* in pressure across the injectors right at 38psi, and this 38psi is the "base fuel pressure".
With a fixed pressure differential across the injectors, and with a specific injector, the ECU knows how long it has to open the injectors to deliver the correct mass of fuel to each cylinder. The ECU has been hard-wired based on a factory tune that works for those injectors and base fuel pressure.
So I don't know why you need to set your fuel pressure higher. If the injectors are flowing normally, then you'd think that a higher base fuel pressure would cause you to run rich (higher pressure difference will force more fuel in a given pulse width than a lower base fuel pressure).
Maybe your injectors are clogged or sticking. I really don't know why this works for you.
I have no idea either its really werid.. It only likes the 43psi base i would love to find out why.. Im going to invest in injectors soon. somewhere between 6-800-cc include the odd numbers but you know what i mean. Im getting DSM link soon. and next fall complete rebuild BR stage 1 bottom end on BR stage 3 head So im just getting my bolt ons ready for the motor.
I hear everyone talking about a DSMlink. I have no idea what this is and im about to do some reading on it but what is its purpose and is it somthing important I should get? thanks and sorry for the noob question
ok now i know what it is... now the question is do i need 1? And if i got 1 how hard is it to figure out how to "tune" your car. What can the DSMlink adjust? sorry again for the questions
