What Turbo use??
racker
79
Oct 24, 2007
Miami, Florida
Hi dsmtunermaniac i have this 2 turbos and i want to know what turbo is better for my dsm gsx 4g63t 1g internals forge and 2 head.
This is the firs turbo TD05H XS Power ar .70 i want to know if this turbo is good or bad turbo??
And this is the second turbo a Garret t3t4 ar.43 is a small turbo but because be garret i think have mire powerfull that the TD05H
thank's for the coments :cool:
Chinese junk. I'm surprised it survived this long.
That's not a T4 compressor wheel....that's your run-of-the-mill Garrett T3; probably standard equipment on an Audi or Saab. Might flow as much as a 14B.
Don't waste your time on either one.
That Garrett will never fit your car in place of the stock turbo unless you change everything.
You'll need a T3-flanged manifold, custom o2 housing, custom oil supply and drain setup...to me it sounds like way too much work and money spent to install a turbo with literally stock airflow potential.
In my opinion, sell those 2 turbos and buy yourself a holset (something like a H1C). You can find those on ebay for like $100
i dont see why he couldnt run the garrett turbo so long as the oil feed is the same as the t25...if thats different he will have to do the oil feed swap...but other than that i dont see it being any different...if the bolt pattern on the t25 o2 housing is the same why not just port to match? thats what they do on a 14b turbo anyways since the t25 o2 housing flows better
honestly though if you are lookin for a good turbo that puts out some good power and still spools quick why not pick up a 20g t3? and a manifold for it
Wait, the garrett he posted wont fit in a t-25 housing? Its a garett turbo as well.
Just because it's a Garrett-based turbo doesn't mean it will fit into a T25 housing. You're talking about a T2 center housing and turbine versus a T3....not even close.
