ECUflash what to log in evoscan?
97ebaygst
326
Oct 8, 2009
thomasville, North Carolina
I've searched on here and the evo forums but I can't find a very good answer so I'm asking my fellow dsmers here, What should I be logging in my evoscan?
Just to list what I do log:
RPM
Throttle Position
Coolant Temp Scaled
Knock Sum
Battery Level(don't find it necessary, but I've been having charging problems)
Air Temp
Timing Advance
Injector Pulse Width
Injector Duty %
Barometer
Oxygen Sensor
Airflow/Rev
Knock Voltage
Airflow Rate gm/s
AFR Map
I know I'm probably slowing down the log speed by logging so much but I don't really know which ones are the most important so i need some advice on which ones i should log All the time.
  • Wanted GSC S2 Camshafts
    GSC S2 Camshafts
    • jmt2028
  • For sale Wideband
    • Briant91
  • Wanted 560 injectors
    • AllanL
  • For sale ACT clutch 2600
    • Briant91
