EVOscan First log - idle
ohlegend
581
43
Apr 2, 2012
Pemberville, Ohio
So after looking at the values I think I may have too much advance on the timing at idle. Also the TPS was showing 14.5~ which needs to be adjusted as well. I was slightly lean at 15.2 AFR (Target idle is 900RPM)
Can someone confirm that I am correct. Also on my first log driving, what should I be logging?
I looks like my advance should be 2-9* at idle, Mine is sitting at 9-13* So I need to turn my cas.
What should my TPS be set at during idle, 11%?
