ECMlink First log (idle)
LiquidX
DSM Wiseman
8,280
132
Sep 19, 2008
Anywhere, Pennsylvania
If this is the wrong section, plese let me know.
I've been slowly trying to read on what to do. This is my first log after some simple adjustments I've done. Clear the CELs, adjust TPS and I believe that's all.
Towards the end I do a 4500rpm (is it called 2 step or launch). I'm a little unsure on my o2 sensor. If you can take a look at everything, let me know on what should be adjusted.
This is all on ECMLink v3
The second log only has target idle moved to 850rpm.
