What thrust bearing do i have?
Deuce of Spades
79
Apr 14, 2008
El Paso, Texas
Is there any way to tell if i have a split thrust bearing without opening the motor? Ive done my research and i haven't found anything difinitive. Ive read that if your car was built June 98 or later it would be equipped with the revised bearings. There have also been conflicting stories about only 99.5 models having split bearings. I have a 98 gsx.
That is the general consensus. By the way, the build date is for cars made after June of 97, not 98. Check your door for your build date.
