What size bearings???
95WTSI
189
Jul 21, 2004
Greeley, Colorado
Not sure if this goes here, but it is about rebuilding... Anyway, I have Eagle rods for a rebuild I need on my DSM. Does anyone know what size Clevite bearing fit the Eagle rods? I got the OEM ones without thinking... Thanks!!! :talon:
Bearings are specified by the grind on the crank, not the connecting rods.
Make SURE that you use 1G rod bearings in your 2G block with the Eagle rods. If you look on the underside of the Eagle box flap (right where you won't look for it. Nice job, Eagle!), there is a sticker telling you explicitly to do so. Both bearings sizes will fit, but the 1G bearings are much more robust, and have larger oilers. I went through this with my 7-bolt Eagle/Ross build.
Matt.
95WTSI said:
O wow!! thanks a lot!! :thumb:
Anytime. Also, make sure that your machinist checks the Eagles before you put them in the car. Sometimes, Eagle rods can be out of round from the factory, and have to be machined again. Luckily, mine were in spec, but I've seen quite a few that aren't. Good luck.
Matt.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
