what sensor is this? is needed? PLEASE help
DSM-Franek
240
Sep 16, 2006
Elmwood Park, New Jersey
has a vacuum hooked up to it but the nipple is broken and the vacuum line is prety much super glued one to it..... what is it ? and is it needed ?
thanks in advance!:thumb:
MAP sensor on the 2G is used as a back-up incase the MAF goes bad. It will go into limp-mode, but will be able to get you home. I would just leave it, as unplugging it would probally throw a code (CEL) on the OBD-II systems.
selmerguy said:
Just a question... The 1g's dont have a map right? Also on the 2g logger can you see boost in your logs?
i have a 6 bolt in a 2g with 2g ecu i do not currently have a logger:|
i have a 6 bolt in a 2g with 2g ecu... if i disconnect the MAP and plug its vacuum line i know itll throw a code but will it put me in limp mode? my MAF is fine
Its not like a 3 bar map sensor because its not a map sensor. It is a MDP Manifold differential pressure sensor, it doesnt work like a map sensor at all, just thought I would clear that up and it is not needed but may throw a code, if you dont have dsmlink or something on those lines.
Tyler
Tyler
ok so to clear this all up. i can disconnect and take out this sensor and plug its vacuum line and have no bad effects? no performance issues what so ever?
thanks for your help guys its greatly appretiated:rocks:
Yes you can take it out and there will be no performance Issue's. I don't run one.
And thanks Skunked for clearing that up I knew it was something like that but wasn't 100% sure. :thumb:
thanks alot guys i appretiate it :thumb:
  • For sale 2g 99 2G parts
  • For sale 1991 Mitsubishi GTO
    1991 Mitsubishi GTO JDM Import
    • jesuschr
    • ist dwa
