What kind of turbo do I need to fit this?
GalantGreg
297
Jul 14, 2008
Spring, Texas
I just picked up this exhaust manifold header for real cheap. Came off a parts car that destroyed the car. They were running 25lbs of boost and a 100 shot of nitrous on a stock block. I don't know what kind of turbo the had. Is there some kind of adapter that will let the T28 bolt up?
Looks to be a cheapy Ebay(SS autochrome ect.) T3 manifold. You could get an adapter but those manifolds are so cheap I doubt its worth the hastle.
x3 Get rid of that thing and port your stock one, or buy one that won't crack on you like a forced performance manifold if you can afford it.:thumb:
With that same manifold, we gained about 1.7lb/min peak at the same boost and spooled the turbo noticably faster with my brother's small16g 2g car before he sold it.
You can run an hx35 with the housing divider radiused with a minigrinder. Or you can run an hy35. Or you can run a 50-trim turbo. Or a 10cm^2 Hahn super 20g. Or a gt3071r/gt3076r/gt35r. Or a Borg-Warner s256/s258/s259. All these have various turbine outlet designs and bolt patterns. All these turbos are easily 11second capable.
