what kind of subframe bushings?
Aproductions
2,123
50
Aug 11, 2009
Allentown, Pennsylvania
So I have the Prothane "total kit" but I want to also replace the subframe bushings.
I am looking for the: (GSX btw)
Front Subframe bushings
Rear Subframe bushings
including the diff bushings
I can't decide if I want solid or poly. Car is not daily driven. but I don't want stuff to break. Noise is not a problem either.
Most common choice?
This might not help much but I personaly like OEM rubber front subframe bushings, and will be doing solid rear subframe bushings when the rear comes out some day. I like OEM rubber for the front subframe for a little "softer" cornering. IDK just my opinion. Mine is a dd though. I would guess Solid all around is the most common choice.
I didn't want to start a new thread, so I decided to post here.
I'm in the same boat. I really can't decide on which bushings (OEM or prothane) This will be a daily driver so I'm not looking for solid beings bushings. Thanks!
    • george bromwell
    • pma1123
    • Sdcryan1
