CNC'ed front subframe bushings
black_gst
2,467
29
Jun 16, 2008
IE, California
these are my new front CNC'ed front subframe bushings!!!
CNC'ed rear subframe bushings and rear diff bushings are in the works and will be done soon!
remember I am just sharing pictures of what I have made for myself.
Thanks!
none have been reported, I know several people that have had them for awhile and have had zero issues and none have even noted added road noise.
for reference if you get under an Evo 8/9 you will notice that both their front and rear sub frames are solid mounted with no rubber bushings.
PM Sent definitely want a set for the front. I have found other companies that do rears but your all I found doing front subframe.
yeah I think split motorsports makes them, but they make a 3 piece rear which i think is a poor design, but Im sure they do it to save money on material
Adam, do you have a installation write-up for these? Just wondering how easy it is to get the OE bushings out.
I dont have a write up, but its very easy. only of of the 6 bushing have a mental outer sleeve and that one is a straight through hole not a cup like the other subframe bushings. the other 4 bushings are just rubber and the pop out pretty easy.
then just press them in
heres a shot with them installed that im borrowing form a customer
after working in a machine shop for a few years i always wondered how these will hold up long term wise. I know at the shop i worked at we would always press in a steel sleeve to prevent the alum from deforming under the stress of the car launching. Every set of alum mounts never have it so i was just curious.
the center bolt hole in the alum mount. just like how the energy suspensions use a steel insert. The alum mounts we made used a thinner steel insert just to help with deformation of the alum. not sure if its needed or not but thats how they were built. just wondering since a bunch of people make them on here without the insert.
I have yet to hear of anyone having this problem, plus i make these holes extra tight so theres really no movement that will allow deformation to start.
Makes sense, was just curious.
