What is this sensor?
RoadRunner2g
3
Dec 19, 2025
Ballwin, Missouri
I tried researching and googling and all sorts but I can’t find a thing about what this could be. I also tried following the wire as far as a I could, and it runs from the exhaust manifold over the top of the engine and into the steering shaft boot. It then runs around under my dash above my pedals and then runs what looks like up the side of the dash, I have pulled the a pillar but the wire isn’t there so I think it goes to something in the dash, but I don’t know. Any ideas? I wanted to get a different exhaust manifold but I didn’t want to pull the trigger until I figured out what this is and what it does.
I figured it was EGT but I couldn’t confirm, and there is no gauge for it so it must have been removed. Is there any chance someone in the past unhooked one of the factory gauges and wired it to the egt? Idk why someone would do that, but ngl the wiring harness has been ran through and there’s random wires everywhere. And is there any way it could be wired to the ecu? I don’t see any readings or custom pin outs set on dsm link for egt.
  • For sale 4G63 7 bolt Eagle rods
    No longer need this, brand new in box. Free shipping using large flat rate priority shipping or...
    • GST2012GSX
  • Wanted 2g Wanted 2G GST automatic tranny
    Looking for a working 2G GST tranny
    • Lonestardsm
  • Wanted Brake Reservoir Bracket
    2g dsm Spyder gst
    • darcd
  • Wanted 2g 2G 4G63T 7-Bolt Head
    Is there anyone in Houston and surrounding areas selling a 7-Bolt head?
    • DSMHERO1
  • Wanted 1g 1g head
    Looking for a built 1g head without cams or cam gears
    • I21chardh
