What is this plug for?
spooled_u_1st
332
17
Aug 27, 2006
Pittsburgh, Pennsylvania
What is this plug for? My tag ripped off. Car is a 1995 gsx auto.
red / green
white / black
It comes off of the main wiring right beside the front o2 sensor.
looks like the ISC plug. Its got enough slack to get around that location.
edit- im wrong. ISC is 6 wires.
this thread is almost a month old, but i figured it out this past weekend - its for the cruise control!
http://www.dsmtuners.com/forums/151528375-post12.html
I also thought that the grey plug was o2 and the black was cruise. I'll check when I get home tonight in my electrical book to check wire colors.
edit: Is the connector that you are confused on in a separate set of connectors from the tstat housing connectors?
It's not the connection in the link.(Cruise Control Actuator) It literally comes off the harness together with the front o2 under the thermostate housing and is just slightly longer (like an inch tops) than the front o2 sensor. There is a mount of the transmission that they both side on, right under the passenger side engine mount.
