what is this and can I remove it?
foxracing4500
336
9
Jan 21, 2012
Europe
purge valve?
do I cap off the hard lines connected to it^^??
-------------hijacking my own thread------
also instead of making a new thread, i'll just ask this. I got an evo big 16g and with the J-pipe being close to the exhaust manifold will that be a problem? or should I heat wrap it like I did in the picture?
You can remove it. If its connected to a vacuum source and it is something other than the fpr, wastegate actuator, pcv, or mdp, it is useless.
thats what I thought, i just ordered so much shit and figured I might as well remove emissions while waiting.
Just wrap your manifold instead, it will keep the j pipe and everything else under the hood cool at the same time. Mine has about 2 cm of clearence and I ran a 12.1 with all kinds of problems/ boost leaks so apparently it doesn't hurt that much.
