2G What is the name of this seal?
ohTONYoh
173
6
Jul 29, 2012
yorktown, Virginia
Just replaced my speedo ring gear, and i noticed i have a small tear in the Driver side seal where the cv axle goes into the tranny. I checked threads and no one has a name for it, i need to order one fast so i need help!
I made a green arrow going to it and tried to circle it too.
I found the part numbers for the seals on another forum.
OEM # 04797334 Dodge dealer.
# M04797334 Mits. Dealer.
Output Shaft Seal is the correct term for them. Yes oreillys and napa and etc sell them.
ATP P/N TO28; National P/N 3459 - $5.95 each at my workplace.
Driver / passenger seals are the same on the Chrysler New Process trans.
Now would be a great time to drain / refill your trans fluid, by the way. ;)
Aww man a little too late. And i did. I was installing a new clutch and i noticed they were ripped so i changed them.
    • jakk220
  • Wanted 1g 92-94 Hood Needed
    • JLavetsky
    • The_Partout_Spot
    • erikoberdorfer
    • ist dwa
