What is the average cost to rebuild a transmission?
95AWD6Bolt
504
Dec 2, 2006
South Jersey, New Jersey
I was just wondering what the average cost is to get a stock rebuild on a transmission for a 90 awd? What have you guys paid in the past?
ranges anywhere from $700-$1000 for a basic rebuild. TRE and ShepTrans is in the $900-$1000 and Dogbox Racing is $725.
To be honest, it might be smarter to "upgrade" to a 91+ tranny because the 90s have known problems but otherwise the price would depend on what in the tranny needs to be rebuilt.
well, there is a 91 tranny in my 90 awd right now. However, I dont have reverse. How do I make it work?
Could just have to adjust the shifter cable, I had the same problem and thats all I had to do. Only took like 15 mins too!
Three options,
1. Swap in 91' shifter assembly and cable.
2. Swap in a 90' main tranny shifter lever, you will have to knock out the roll pin that holds it to the shaft, difficulty of 9/10 but not impossible with the right tools.
3. Since the 91" tranny shifter lever is longer than the 90' lever, measure the length of the 90' lever, drill a hole on the 91' lever matching the measured length, nut and bolt your shifter bushing to the hole.
ok hopefully i can at least get it to work. I really dont wanna go out and rebuild a tranny right now. I know it will need to be rebuilt eventually.
    • george bromwell
    • pma1123
    • Sdcryan1
