what is a short throw shifter
B&M makes one that shortens both the throw and the height of the lever. They're tough to find nowadays because they've been discontinued. I'm sure you can find them on eBay or Amazon.
Its a shifter shaped like a base ball that hangs from your roof, its used like a normal shifter but you dont have to extend your arm as far like if you were throwing a real baseball.
That looks like the Megan Racing one...:
You are correct, sir. I just googled a pic and it was the first one to pop up. It's essentially identical to the B&M one that I have in my car, which I highly recommend. I was amazed that it dropped the height enough to actually see the display on the radio. :thumb:
How is it working for you?? I have been reading some mixed reviews about 'em..
I'd like one for the fact that the rod isn't so long 2G stock one is in the way of my 6.5 inch Screen! :cry:
If I buy the megan racing one, or any short throw for that matter..
can I use the shifter rod for the purpose to just have a short rod and not attach the little adapter to make it a short throw? I dont want to grind any gears as some have said. Its a not a true short shifter unless you cut the cables and I dont want to mess up my syncros..
This just in... for anyone else looking for a S/S.
http://www.dsmtuners.com/forums/ven...0-dsm-short-throw-shifters-now-available.html
Well techincally that does reduce the throw, it just increases the force (minor) to move from gear to gear. Grinding it down is a very horrible way to do it though.
