What injectors do I have?
tmannix
Aug 25, 2006
glendale, Arizona
Hi. I Have A 98 Eclipse Gs-t, I Blew The Engine, And The New Engine I Got Had A 13g Turbo On It, So I Am Assuming I Have A 1g Motor Now. Anyway, When People Have Their Engines Swapped Like I Did, Do They Keep Their Original Injectors, Or Do New Ones Come With The New Engine? In Other Words, Do You Guys Think I Have The Original 2g Injectors Still, Or Do I Have The 390cc's That Came On The 1g Automatic Cars? Thanks
You most likely have 390cc injectors. Will need to switch them out for 450cc injectors because the computer in your car is going to think they are 450cc's. Without actually seeing them I can't tell ya for sure though. What color are they? And less capital letters.
I Am New To All Of This, So I Was Wondering How Easy It Is To Check What Kind Of Injectors I Have? I've Heard Before That They Have Different Color Tops. Is It Easy To See Which Ones I Have? Can You Shed Any Light On This For Me. I Appreciate Your Help. Tom
Ok I just checked, and the tops of them are yellow. are those good for running a s16g in place of my 13g? thaks guys, for your help.
As long as they are 510cc. Could be EVO injectors as well. I would get them flow tested. Yellow is a pretty common color. 510cc, 560cc and even some Hyundia cars had yellow one's that would work but not sure on the size but they were rather small.
Are you sure you dont have a 16g on that motor. The jdm engines that came with the yellow top injectors normally came with a s16g.
Ya. I'm Sure It's A 13g. I've Had To Replace It Once Already, And When I Took Out The Turbo, I Wrote Down The "serial Numbers" And Did Some Research, And Found Out That I Had A 13g. It Is A Really Small Turbo. Thanks Guys. Tom
If you have 450 or 350 it should say on them...and the 13g came with the td04h comp housing so you shouldn't have to write down a number. It doe sound like you have 510's which is good for you.
