What fittings for quick turbo installs ?
GDNF2ET
586
11
Feb 12, 2003
VA Beach, Virginia
I would like to be able to switch between my two turbos quickly..One is a BB35r the other is an HTA68...Both are water cooled. The turbo oil and water fittings are my only concern for this thread..
The oil feed for each is worked out and proprietary..
I would like to have a fitting on the oil pan for the drain that will stay there and not be removed everytime I switch turbos..The water feeds are still banjo for now and the 35r fittings are larger then the HTA68....
Go to advanced auto buy some 18mm (at least mine were 18mm, you might have to bring the turbo's in like I did to match em up) barbed brass water fittings, and then some rubber hose and clamps... Both will have similar fittings and both accept the rubber line...
I don't understand how that would make changing the turbo a faster process.
Once installed, just loosen the AN fitting to remove turbo drain.. No gaskets to deal with..
  • For sale 2g 2G AWD Rear Knuckle Set
    2G AWD Rear Knuckle Set $230 + shipping and paypal fees* these are out of 2GB so you get a...
  • For sale 2g 2G GSX/GST Front Knuckle Set
    2G GSX/GST Front Knuckle Set $150 + shipping and paypal fees* on the L side Knuckle the little...
  • Wanted Looking for an Evo 3 16g
    Anybody selling one let me know. Tried ebay and its all knock offs
    • heresjimmy42
  • For sale 1g 1990 STM shifter base bushings
    1G 1990 STM shifter base bushings.
    • drich970
  • For sale 1g 1G Radium fuel rail
    1G Radium fuel rail with built in FPR -8an feed and return
    • drich970
