What do you think??????
95tsiawd0330
124
Feb 9, 2012
woodlyn, Pennsylvania
Hey guy I have a 2g talon awd that has a 6162 percision turbo on it and the car is running on speed density.the other day I pulled the plugs out and seen that they all had black soot around the ring but in the middle of the plugs were gray.and I noticed that when I start to get in to boost I leave and puff of black smoke does this mean that my globle on ecmlink is set a little rich.or what well cause a puff of black smoke for a second and then just clear right up?also just to mention I have did a boost leak test,put in new plugs,new gates timmin belt set dead on,timmin set at 5*,new filter ran down by the fog lights ect...............
well just from your description of one of your plugs it sounds like your running rich. what cc of injectors are you running? you might have to change the global. what about deadtime?
i have 880cc and my global is set at 46.5 which is for 840cc because my injector don't flow at 880cc they flow at 840.and my dead time is set at 290 but I think that is for idle only but I could be wrong.
