what do you think it is
redrockergsx
84
Feb 16, 2010
el mirage, Arizona
I just data logged my car and was running 15 to 18 psi cant tell cause the car cuts off. I ran it up to 4500 rpm and it cuts off.
The data logger show .80v to .90v on the o2 im running 0 to 2 knock
was just wondering if you the car had a boost leak would it seem like the car was hitting fuel cut
Cause the car runs absolutely perfect at 12 psi and not cut offs zero knock just the best you can think off so it has narrowed down to a boost leak just seeing what you think.
Not sure if you guys need it but the car is running a garret 50 trim with a safc, 750 injectors, 255 walbro, 272 cams, 2g maf that im going to gm maf,
seems like your over running your stock fpr....get your self a AFPR. Also, you're running 750 injectors with a safc....you"re going to have a really tuff time tuning with a 255 fp, 750 injectors with a safc....you wont be able to lean out enough with that setup. Right now you are running way rich
