What Do I Need?
nek
832
9
Apr 17, 2009
Pittsburgh, Pennsylvania
Alright, so Ive had my car for about 3 months now and Im starting to notice lots of the temporary problems.
My car is leaking and burning oil. Dont know from where dont know from what. Usually when Im sitting idle, no smoke is comes out but when I hit the acceleration, you can see white smoke.
Also, when I first got the car, it was idling at 1000rpm where as now its sits constant as low as 400rpms.
A few days ago when I noticed it, I rev'd the motor to 2000rpm then let it sit back to idle and the car staled (automatic).
My headlights get brighter when the car is moving even though I cleaned the connectors and terminals.
And last but not least, I cant get my brake disks off. Hammer, Heat, Spray, nothing.
I know my problems could be due to a number of things but any kind of input or opinions would be sweet. Thanks.
Probably your piston rings leaking, do a compression test and see just how bad it is. How to do a Compression Test
Also, when I first got the car, it was idling at 1000rpm where as now its sits constant as low as 400rpms. A few days ago when I noticed it, I rev'd the motor to 2000rpm then let it sit back to idle and the car staled (automatic).
Probably a vacuum leak, do a boost leak test IC Pipe Tester , make sure to use a spray bottle filled with very soapy water and spray everything down to help make leaks more apparent. Fix all leaks.
Battery/alternator starting to fail. Probably battery. Take it to autozone and have them test both alt. and battery.
Work out more and get a hammer with a longer handle on it. Or just get some huge friend or friend's dad to help you out.
Learn to use VFAQ Site - Visual Frequently Answered Questions and search it's wonderful pages. The 1000 questions faq is amazing.
White smoke on accel means likely . . .
1. A blown turbo: oil doesnt burn completely if it's being pushed out of the seals like it burns in the combustion chamber from worn rings; or
2. A blown head gasket: the gasket is sealed enough for idle and light cylinder pressure, but as soon as you put higher cylinder pressure against it as in acceleration, you get water/coolant leaking in to the CC.
For 1, pull the intake pipe and check the compressor wheel for shaftplay.
For 2, Does the water level in the overflow rise after driving for a while? or do you lose coolant/water?
LOL are you sure its getting sucked in? Your fuel tank is a sealed system with emissions controls making it pressurize or depressurize. Its no big deal your gas cap just has a good seal is all.
phew. alright good. one less thing off my mine. I like the white with green you got going. looks sick
