What do i need?
baz938
Nov 8, 2005
Revere, Massachusetts
i jus bought a 1g bov w/ pipe from ebay but i cant find exactly how to install it...do i need A FLANGE, OR HOW DO I PUT IN THE PIPE
if your putting the 1g bov on the stock 2g piping then yes you do need the adapter..you can find it on ebay for like 20 bucks if you have an after market pipe just bolt it on..or depending on what your pipe is set up for try to drill it out a little.
Yes. (see above.) Use a gasket, and you might as well get an aftermarket UICP instead of that adapter. the adapter is 20bucks, but you could spend just a little more for an upgraded pipe. lookup the David Brode pipe. It's basic, cheap (inexpensive, not crap), good looking, and effective.
