what do i need to make a 16g fit on a 2g gsx
You'll need a new oil feed line. BoneHead performance sells a cheap one that works perfect. You'll either need a stock 1g oil return line or you can do what I did and drill out the bolt holes on your stock oil return tube. Then you'll need a jpipe for either a front mount or if you're on the sidemount they make a kit to make it bolt up. I belive that's alll you'll need. Make sure to get new gaskets for turbo to manifold, turbo to o2 housing,and oil return gaskets to the turbo and to the oil pan. I'm pretty sure that's it.
The Extremepsi 2g install kit fit like a charm. It gave me no problems at all and comes with everything you need.
EXTREME PSI : Your #1 Source for In Stock Performance Parts
If you want to crank up the boost then you will def need some fuel like clipto said. You can also check out this recent thread which has some pretty good info on what you will need if you plan on upgrading your fuel and cranking up the boost
http://www.dsmtuners.com/forums/newbie-forum/457151-i-need-help-choosing-injectors-new-turbo-set-up.html
