What did you do to your DSM today?
Swapped rubber/nylon braid fuel lines for SS/Teflon fuel lines with heat-shrink cloth sleeve. Installed a leak proof sight gauge on custom coolant overflow. Re-wrote code for the cell phone alarm thingy and installed it in the car.
That's cool as hell. How does the cell phone thingy work exactly?
Water pipe, Water Neck, T-stat Housing :)
Carpet came out really dark blue (not enough dye I guess)
Started scrubbing straight black rit dye into the carpet. It's black now.
Dropped off most of the front suspension for blasting/powdercoating.
Did the spark plug mod posted in the site below and it really does work !
http://www.instructables.com/id/Save-Gas-And-Incerase-Horsepower-By-Side-Gapping-S/
Went to O'Reilly's and bought a set of Autolite 63's and modded them to run side gap.
Cut off the electrode, gapped it down to .018" and did the install.
Definite increase of performance with a lot smoother idle, along with having to turn down the idle speed a bit, since after the install, my RPM settled in close to 900 RPM, thus had to scale it down back to 750RPM.
Quite impressive !
-DSM
Installed megan racing downpipe catless to my srs 3inch exhaust and weapon R polished aluminum coolant reservoir and mud guards.
pulled some parts off the parts car, found some kewl stuff, and deduced that the motor is...FUBAR :D haha
pics!
Hooked up laptop to ESi. P0455 again. I guess I still have a leak somewhere. :banghead:
Seems to be a clicking sound around the gas tank when the light is on. It stopped after I reset the code (altho the car might have just warmed up)
Scotchguarded black TSi carpets.
Mocked up my front RA style mudflaps with cardboard.
Installed black trunk carpet.
Pulled ABS Ecu, Relay, Bulb.
Pulled out crappy fitting A-pillar Gauge Pod.
Started dissecting all this wiring crap from PO :banghead:
EBC will be moved from steering column (ziptied & taped) to glove box.
Well, in an attempt to pull my 6 bolt out of my 1g to use in my 96 auto awd I f***ed my hand up pretty well. I managed to get the downpipe, t-case and driver side axle out before I did this.. While trying to get the passenger side out I had to heat up the spindle to free up one of the two bolts that hold it to the strut. After that came out I was trying to get the axle out of the hub and in the midst of things I grabbed the exact spot I had just heated a few minutes prior.. This is the result.
  • Wanted OEM Front Mud Guards
    ISO 1GB Eagle Talon OEM Front Mud Guards
    • Cj Anderson
  • For sale 2g 2g auto speedo gear
    2g auto. 97-99 speedo gear. From a GST trans. 29 teeth. Price is shipped Message 702-741-6987
  • Wanted 4g63t Valve Cover
    Looking for an uncracked 4g63t valve cover
    • victim
  • For sale AUTO DSM 91-96 300M UPGRADED TRANSFER CASE
    One of my spares Beats having to ship and waiting 8 months. Can do asking price or $1340 w/ your...
    • The_Partout_Spot
  • Wanted 1g Looking to buy a 1G turbo AWD
    Looking to buy a manual 1G turbo AWD DSM — GSX, TSi AWD, or Laser RS Turbo AWD near the states...
    • Rtsr
