What causes premature TOBearing wear?
burnnxs
156
Jun 13, 2006
l, South America
I'm getting grinding noise from the tranny either when in neutral or in gear but it goes away when the clutch is pressed in or I give it some gas while crusing.
So I think that I might have a bad TOB but it was replaced about 10k miles ago with a new SBR 4K clutch and Fidanza flywheel.
What could be causing such premature bearing wear?
Could a bent fork or pivot ball cause this noise ?
Having a slowboy clutch is your first problem, and they use OEM TOB's
No problems with my SBR clutch over here it holds like a champ. It's the redesign version of the 4k series.:thumb:
What causes premature TOB wear?
Faulty TOB or not greasing it correctly/enough.
The noise would go away when you press the clutch in, but it shouldnt be RPM dependant.
