what cams for a 2.3 stroker ?
dan2288
577
Sep 9, 2006
Shillington, Pennsylvania
I was thinking bc 280's. Will that still give a a rough idle(i like that:thumb: ) on a 2.3 or should I go bigger ?
ok, sounds good. I already have bc springs and retainers sitting here. Just have to get the other parts.
I have Comp Cams 200 (FP2), with 2.3 stroker. 8.5:1 compression with with stock head. The head has rebuild with 3angle work done to it. I use MAFPRO for tuning and it idles at 750 with ever so slight lope. I'm just getting this tuned. So far 20psi at around 3800rpm like a freight train and then some more umph at about 6500rpm to 8000rpm. I like them better then the 272's I had on my 2g 2.3 stroker, but that was with a 50trim. This is a 35R internally gated so yeah a little more umph.
