Resolved What bolt goes here?
PrimerPLus
1,160
20
Jul 28, 2011
Tokyo, Asia
Can anyone give me the bolt size and pitch and length that goes in this empty spot?
Thanks!
So I went to Fastners and got these bolts M12 x 90mm with 1.25 thread pitch to throw in these empty spots. The bolts were grade 8.8 and they will not go all the way in. Are these suppose to be pointed? I tried and had to crank on them very hard but had about maybe 2 fingers width left and I could not get it to go in any further. I tried to find a picture of these bolts on the net but no luck.
Just cut it shorter if you need to.
Or go to a junkyard and scour Mitsubishi cars until you find a bolt that will work.
Buy them from one of the part outs on this site..I'm sure someone could hook you up.
Ok so I got new bolts and I was able to get the one all the way in but as it was all the way in it just spun. This time I did it on the driver's side. Last time I did not even bother with the driver's side because I just assumed that this side would not go all the way in either. But this one went in with ease and I had to apply pressure to get it to go in but it never really felt like it was threading, I just assumed it was really clean haha yah right... After the bolt was all the way in and spinng with the ratchet, I was able to pull it all the way out by hand.....
Well here is a picture of the hole Also a video.
So what is missing on the other side?
IMG 08031 - YouTube
Looks like the threads are missing. You might have to drop the subframe, drill the hole out a bit and install a helicoil, or just tap it for a bigger bolt. You would have to drill the sleeve in the bushing out a tad to do that though. The other option would be to cut a small hole thru the floor board above where that is. There is a nut that is tack welded on the inside. You can break the nut loose and just put a nut on thru the hole that you cut.
Some good advice thank you. I think I might drill a hole instead of droping the subframe LOL. We will see though.
I don't doubt it. I have discovered so many things with this car since I bought it. Previous owner was a complete...well uneducated person LOL.
