[RESOLVED] What goes here?
Colt90tsi
202
Dec 28, 2007
Lake Stevens, Washington
So I ready to drop my freshly rebuilt 6 bolt in and was wondering what goes to the bolts circled in the red:
This is on the back of the block down near the oil pan:
<a href="http://s423.photobucket.com/albums/pp317/Colt90TSI/?action=view&current=noname1.jpg" target="_blank"><img src="http://i423.photobucket.com/albums/pp317/Colt90TSI/noname1.jpg" border="0" alt="Photobucket"></a>
<a href="http://s423.photobucket.com/albums/pp317/Colt90TSI/?action=view&current=wtfisthis.jpg" target="_blank"><img src="http://i423.photobucket.com/albums/pp317/Colt90TSI/wtfisthis.jpg" border="0" alt="Photobucket"></a>
<a href="http://s423.photobucket.com/albums/pp317/Colt90TSI/?action=view&current=noname.jpg" target="_blank"><img src="http://i423.photobucket.com/albums/pp317/Colt90TSI/noname.jpg" border="0" alt="Photobucket"></a>
Also, does anyone know if a subframe from a 90 awd is interchangable to a 91 awd?
first pic looks like the ac bracket and the teo at the bottom are where the drivers side axle bolts to the block.
second pic looks like where the little bracket that goes to youe drivers side motor mount to that bolt.
third pic is where yoiur oil cooler lines go.
Im not sure on the sub frame but i would'nt see why not,90-94 should be the same someone correct me if im wrong.
1st pic. AC bracket uses 4 bolts. The two on the left and the one to the right of the top left one and the one below it circled red. Driver's side axle shaft for the two circled right ones. Without the AC bracket you will have to shim up the left bolt with some washers or something. The axle shaft mounts over the AC bracket on that one bolt.
2nd pic. Goes to a little arm that connects from there to the driver's side motor mount. I generally leave this off. I don't see a purpose for it.
3rd pic. That is a '90 Oil Filter Housing and the two circled holes are where the lines for the air cooled oil cooler goes to.
I'm pretty sure the '90 subframe is interchangeable.
as for the 1st picture well 3 of the holes you have circled in red, I used it for the Jay Racing Alternator relocation kit on a 1G
